Hi. I finally managed to get another supply and boot up to check if my components were working, but, now when i turn the motherboard on it cycles through all the post leds and then stays with the boot device led turned on, and i get no image in the monitor, but my mouse and keyboard turn on. Also the motherboard on-state leds turn on and the fans start spinning.
I have a HDD connected in the "boot drive" labeled sata connector in the motherboard.
I tried with 1 ram stick (i have 2) in the a2 slot and b2 slot separately, and with both at the same time.
Everything is connected correctly. I only connected the 24-pin motherboard connector and the 8-pin cpu connector.
I tried removing the cmos battery for 15 minutes with the pc turned completely off.
No usb stick is connected. Only connected devices are the mouse and keyboard (in the usb 3.0 slots) and the dvi-i for my monitor.
The first time when i booted the motherboard without an HDD the speaker made some beep (sounds), but after i connected the HDD i had no more beeps when booting it up.
Nothing of the above worked. It still stays with the red "boot device" led on, and without displaying image.
My motherboard is a z170-a from asus. (16gb (8x2) of crusial ballistix 2666 mhz ram, i5 6600k, 212 evo cooler.)
