Hello, this is my first post here, so welcome everyone
Here's my problem. I recently bought an HDD Caddy for my Acer V3-571G laptop. In my standard hdd sata slot I have an SSD drive (ADATA 256GB), and I wanted to have a secondary one (TOSHIBA HDD 500GB) as a replacement for my optical drive. The problem is, when I set this up, I can't force my BIOS to boot from the drive that is in the primary slot (ADATA). Instead, for some reason it chose to always use my hdd caddy as a primary boot device - I'm completely out of ideas why...
I have InsydedH20 bios (version 1.13) and its boot options capabilities are pretty limited. I'm pasting all screenshots from my bios screens:
I have already tried all different kinds of the boot order in bios - no results.
I have tried "Enter" on each listed item (especially on HDD0 item) in hope to see a menu with a choose option - unfortunately not 🙁
I formatted the drive that went to the caddy (TOSHIBA) so it's completely erased.
When I remove the caddy, then in bios boot options ADATA is correctly listed. When the caddy is in, the Toshiba name is there. It somehow overrides the primary sata slot.
The only thing that I was able to do, was enabling F12 boot menu at the startup, so when I press it, I can finally see a choose option for the drive to boot from (both of the drives are listed). When I choose the correct one (ADATA), it starts as I expect, I can see both drives in my system and I can easily read/write to the one that is in the caddy.
So the problem seems to be in BIOS (I guess) but I don't know what should be the correct step to make it work.
Does anyone have any idea why is this happening? (And is there any way to make it work?)
Thanks
Thanks
