Boot Problem- Please help :(
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Hey guys I got a problem. When I reboot my Win2k OS I get the blue screen saying "Inaccessible Boot Device". It saids to try rebooint again and then run virus check, remove and reinstall drive or run chkdisk for errors ;( I can' tget into my system! please help me fix this :-/
Mike
There is a "repair installation" option in Win2K; hope that helps.
Rob
Please visit <b><A HREF="http://www.ncix.com/shop/index.cfm?affiliateid=319048" target="_new">http://www.ncix.com/shop/index.cfm?affiliateid=319048</A></b>
hey, where is this Repair installataion option? I can't even get into the OS if I can't boot =/
If you post here, there's no need to send me a private message. It's actually better to just post on here, so that others can help you too, if I can't. And double-posts and the like really annoy me :)
Just use the 4 Boot disks from Win2K (you can create these from a DOS prompt by booting up with a Win98 startup disk), and there should be a "repair installation" option. Navigate into the Bootdisk folder of your Win2K CD in DOS and create the 4 disk-set from there.
Rob
