Ok, currently I have a raid (1) disk array and it's having some problems, at least I believe it's a disk problem as when I do a scandisk, it can't repair a system file. I would think that raid (two duplicate hard drives) would repair this, but apparently not. The disks are Western Digital
Currently, I don't dare shutdown my computer and I never know if it will successfully boot up again. The last time I spent two days trying to fix the problem and then, suddenly, it booted after no apparent change was made.
Because I'm having problems, I made an image of my computer and put it on my NAS.
In any case, I'm thinking my best plan is to either break the raid and reinstall my image there, or get a new hard drive and install it there.
I plan to upgrade the computer to Windows 10 in January.
My plan is sort of like this:
Does this plan make any sense at all?
Oh, btw, when it doesn't boot, I'm getting These error codes
problem signature 01: 6.1.7600.16385
problem signature 02: 6.1.7600.16385
problem signature 03: unknown
problem signature 04: 176
problem signature 05: AutoFailover
problem signature 06: AutoFailover
problem signature 07: NoRootCause
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1033
Any thoughts on which direction I should take above and whether this approach is advisable at all. I suppose my problems could be memory or motherboard related also?
- Get the W7 box stable so it will boot. I assume I'm having a hard drive problem, not memory or MoBo because it will boot sometimes and sometimes not. Also when I do a scandisk, it tells me there is a dll that cannot be repaired.
- To do this, either break the raid and figure out which disk is bad, or get a new disk and install the image that I made onto it.
- Upgrade to W10
- Take an image of W10 and, when I get a new computer, install it there so I don't have to reinstall all my programs and data.
Locale ID: 1033
