Boot Problems: "Error Loading Operating System"
rORy
31
Archived from groups: microsoft.public.windowsxp.general (More info?)
During general use of Windows XP, my PC crashed and I therefore had to reboot
it. However, now it comes up with the message "Error loading operating
system" in the boot phase. I have used the Windows XP CD to get to the repair
console, (by pressing 'R' on the first screen, only I don't know what to do
from here.
Any help as to how i can repair my PC is greatly appreciated.
Thanks.
Rory.
G
Guest
Guest
Check here:-
http://www.michaelstevenstech.com/XPrepairinstall.htm
regards,
ssg MS-MVP
> from here.
> Thanks.
> Rory.
demax
6
I don't think the console will be of any great help. I found it only good to fix the MBR and fixBoot.
You need to actually continue loading (as if installing a new operating system) which will take you ultimately to a new option to (1) load a new Windows or (2) do a repair.
The Repair choice also uses the "R" key.
If you are not familiar, how to. There is a detail post here: http://www.tomshardware.com/forum/244555-45-performing-repair-reinstall-winxp-tips
I've done repairs many times. It works 90% of the time.
kenrivers
Illustrious
Not exactly sure how removing and reinstalling the SATA cable will help here. Usually this message relates to a problem with the OS (hence the suggestion to use Windows repair) or it could be a physical problem with the HDD. demax has posted the most helpful suggestion.
Similar threads
