I'm having an issue with my PC, I recently spilled some liquid which fell inside the case through the top fan vents. I quickly opened the case and started taking apart any components that I could see that appeared wet. I cleaned as best I could with a lint free paper towel anywhere I could see wet spots. I took apart many affected parts, including CPU heatsink, GPU, RAM, etc. I got everything as best wiped off as I could and set them all out overnight infront of a desktop fan to air dry over night. In the morning I inspected everything and it looked fine, didn't appear wet anymore and no visible damage or marks like anything had shorted.
I began to reassemble everything at this point, then upon powering on it appears to power on fine. I can access the bios, windows starts to load but then crashes before windows starts. I tried many options, last known good config, start up repair, chkdsk. Then I try safe mode, it loads under safe mode. So I try to do a repair from my windows 7 disc, I go into safe mode and do a selective boot with no windows services or drivers loading on startup. But nothing will allow it to load under normal start only safemode, and even then sometimes it doesn't load on safe mode.
I then decide to format that drive and install win 7 fresh, install goes fine, it boots up perfect to windows. Everything is running, then I start doing updates and install needed drivers. Then upon reboot it starts doing the same thing, won't allow windows to start. I do a system restore back to the point before I installed any updates, and this allows it to start up again. I try to selectively run small batches of updates at a time to see what is causing it to suddenly break again. But it is inconsistant, and I can't really determine what is going on.
So my question is, why would spilling a liquid on my PC allow it to work perfectly fine with safe mode, and after having a fresh windows install, but it doesn't work upon loading certain updates or drivers?
