booting problem help
khalidTheThird
25
hi guys i have a problem when i boot up my pc sometimes everything is fine and it boots up to windows but sometimes it boots to the bios and i think that it cant detect the HDD because i cant see the HDD that has windows on it,so i would have to restart my pc few times for it to open windows
Try disabling fast boot options in BIOS.
It's possible - your drive is not being initialized fast enough to boot in fast mode.
What's your motherboard model name btw?
Check the Sata cable or whatever cable connected to your MB. If connection is good, you may need new cable or MB has some damage, you may try a different Sata port on the MB.
1-yes i checked the cables they are very secure
2-my secend hdd works fine and it has the same cable as the one that is not working,but no i didnt try a different cable
3- i dont know how to run a health check i dont even know what health check is
the cable is connected and secured,my MB is new in fact all of my pc parts are new
this is what i see when i did the health check,https://ibb.co/kTNSg5
i dont even know what is HDtune health
i switched the cables and nothing happend the other hdd worked (the one that always worked) and the one that has windows on it didnt work again !!! and i did the health check https://ibb.co/kTNSg5
the hdd is new,and like what i said before all of my pc parts are new
HDtune health test
1-https://ibb.co/nPQsik
2-https://ibb.co/fiE2ik
