Booting problem of my oc
May 4, 2018
I tried to load the windows xp in my pc but the problem is after the configuration copied, the process will repeat, what should i do?
You want to install Windows XP, but installer gives error on Copying files?
If yes, i had same problem. Try again (3-4 times, sometimes it works without anything). If problem continues, try detaching and reattaching your SATA of HDD (i don't know why, but it worked everytime i tried).
If no, please give a larger explanation. I didn't understand. If you can, send an image.
