Good day guys!
I got troubled with my rig, I recently upgraded my motherboard to Asus Striker II formula. The problems is when i switched on the CPU it takes one to two minutes before the ROG logo appears, from that time(1-2 minutes)the motherboard is on, the video card is running(the fan is around 50%+ then back to 20% then back to 50% vice versa... until the system start up it back to normal 20%)
Also, i cant use the PCI-E slot 2.0, when the card slotted in PCI-E 2.0 the monitor just blinking for the whole time(exactly the same like what I stated above about the slow or long boot time that takes one to two minutes)
So im using 1.0 x16 instead
Here's my spec
Asus Striker II Formula
E8400 (no oc)
MSI n250gts 1gb 256bit OC ver
2x2gb Kingston 667 ddr2(not low profile)
320gb HDD seagate (sata)
80gb HDD western digital (sata)
Creative Sound Blaster VX (i dont have the original supreme fx II of mobo so i use this)
Tacens Supero 600w
LG dvdrw optical drive (sata)
Accessories
Deepcool Rockman
Deep Cool Ice blade, push pull setup (stock fan + 1pc windblade)
120mm stockfan of aerocool vs-9
120mm x4pcs deepcool windblade fans
Note:
old mobo:asrock conroe 1333 667
what seems to be the problem?
Here's my spec
E8400 (no oc)
Tacens Supero 600w
Accessories
Deepcool Rockman
Note:
