Not sure if this is the correct forum for this, but it seems the most appropriate.
Here's the problem I hope you guys might be able to help me with:
There are three things going on, which I suspect are all interrelated. This is what might happen:
1) Turn the PC on. It goes straight into standby mode as if the GPU is broken, or not present.
2) POST detects the CPU but where it should say how much memory is installed, and speed, it either says "None", or some random nonsense such as:
CHS, SATA23, 189GB
CHS, SATA192, 3303MB
There are a few others along those lines and this is the most common of the three.
3) It POST's but when it comes to booting from the HDD or CD it hangs with a flashing cursor.
None of these errors, if you want to call them that, produce POST beeps.
Whichever one happens, a quick reset, or a couple of resets, usually fixes it. Either way, once it starts loading windows it's absolutely fine. No further problems. Reseting the PC from Windows is also fine.
I've opened it up and had a good look around. Nothing seems out of place, loose, corroded etc etc. I've also tested the PSU and that checks out.
I'm tempted to think it's the motherboard, but unfortunately I don't have another I can try.
The PC is nearly two years old.
Do you guys have any ideas? Thanks in advance.
System specs:
AMD 64 x2 5600+
Asus M2N32-SLI Motherbaord
XFX 9800GT 512MB GPU
OCZ 600W PSU
Crucial 4GB PC-6400
Seagate 250MB HDD
Creative X-Fi Xtreme Gamer Sound
NEC DVD-RW
Windows Vista Home Premium SP2
CHS, SATA23, 189GB
System specs:
AMD 64 x2 5600+
OCZ 600W PSU
Crucial 4GB PC-6400
Seagate 250MB HDD
NEC DVD-RW
