Hi,
Please help!!
I built my pc over 3 years ago and it worked for about 6 months until I moved away from home for 2 weeks but when I came back when I tried to turn it on but the psu fan and cpu fan spins for about 2 seconds then stops I can't get it to display a bios or anything I even brought a on board speaker to see if it beeps anything and nothing displays on the onboard display on my motherboard either
I then tried to boot it with just the cpu, stock cpu fan, psu, motherboard and ram but it didnt make a difference the same thing kept happening!
Over the years I brought parts to try and find out what is making it not work
First I brought a motherboard and that didn't make a difference
Then I brought some more ram but that didn't make a difference!
The only other thing I can think of would be the cpu
But after trying different things from posts from the Internet I realise if I don't plug the 8 pin cpu cable into the motherboard it runs perfectly with the cpu fan keeps spinning and so does the psu but obviously no display since the 8 pin wasn't connected!
Does this mean that I have either shorted 2 motherboards because how unlucky I seem to be or do you think it's more likely to be the cpu? Or do you think it could be something else?
Thanks
Specs:
Cpu -
intel i7 4770k
Motherboard -
Asus maximus vi hero
Then got
Asus maximus vii ranger
Cpu cooler-
Corsair h100i
then used
Stock intel cpu cooler that came with the i7
Ram-
Corsair dominator gt 8gb x 2 ddr3
Then got
Fury hyper x 4gb ddr3
Psu-
Corsair Ax860
Then got
Corsair vs550
Please help!!
Thanks
Specs:
Cpu -
intel i7 4770k
Motherboard -
Then got
Cpu cooler-
Corsair h100i
then used
Ram-
Then got
Psu-
Corsair Ax860
Then got
Corsair vs550
