G
Guest
Guest
I have recently built a new system, but I am using the harddrive from my old computer until I get a new HD as well. The first couple runs went nicely, then I went ahead and installed Win2k over the current Win98 installation (to clear up any compatibility problems with the new motherboard).
One time I rebooted, during the Win200 graphical bootup screen it turned blue and gave me a stop error, "INACCESSIBLE_BOOT_DEVICE" (or something similar). It said the if this is the first time, just restart, so I did. It worked fine the next run.
I had it running for about 24 more hours, then rebooted again, and got the same stop error. Unfortunatley, no matter how many times I reboot, the stop error still shows up, so I know there is something wrong. I tried to unplug then re-plug the data cable to the hard drive, but it didn't work.
Can somebody explain to me what causes this error are, and any other tips to possibly solve this problem? Any help would be great.
-symband
-symband
