borderlands 2 AND bioshock infinite crash on 2k logo. HELP
zqa20
582
I really enjoy bioshock infinite and today i was planning another play though low and behold when i get to the 2k logo my computer locks up and crashes the exact same issue on borderlands 2.
This doesn't happen on ANY other game i have.
i've tried
re installing the game
re installed all of steam -.-
What kind of crash do you get? A crash to desktop? Does your computer freeze then unfreeze? Just outright freeze and you have to reboot to fix?
Have you installed any DLC since you last played Infinite?
No promises, but try updating GPU drivers.
Feels like an issue related to bink player. That usually comes with the product you install, but getting it fresh off the net might solve the issue.
Also, more than a fix, it's a workaround. Usually, if videos are missing, a game just skips reproducing them.
Why don't you try renaming the video files? It should just skip them entirely.
The computer locks up and freezes and makes a really load buzzing sound through my headsets. i have to reboot the computer.
tried different drivers and i have no DLC for the game
How can they be missing? I've re installed the game 5 times along with verifying integrity of the files
They can be missing if you rename/move them. If they're missing, the won't get reproduced but rather they get skipped, hence your game won't hang on them unless there's a specific check wanting them.
I was hinting at the fact you should rename them yourself ON PURPOSE. If the game doesn't find the files, there's a good chance it skips them entirely.
Nevertheless, I missed the part about the fact it's from steam, so I doubt it's a corrupted bink player. Should the above workaround fail, it could very well be a driver incompatibility, so I suggest you update them.
Found some interesting info
Loaded the game up in window mode and clicked off the borderlands 2 tab and let it load up. it was loading up just fine UNTIL i clicked on the BO2 tab then my computer froze up;/.
