Borderlands 2 Freezing Problem
tyler36
31
When I would play borderlands 2 for about 5 minutes it would freeze and I have to turn it off from the task manager. I have tried running it on the lowest settings too but it still freezes.
Any suggestions?
CPU: i5-3470
GPU: Gigabyte 650 ti 2GB
MOBO: MSI Z77A-G41
RAM: ADATA XPG V1.0 series 8gb (2x 4gb) DDR3
OS: Windows 7 Home Premium x64
I'm not sure if you need anymore specs, just ask if you do.
I'm also not sure how to get the temperatures of my computer.
Ok, I have the temperatures.
Mobo:
TZ00 Min: 28*C Max: 28*C
TZ01 Min: 30*C Max: 30*C
TMPIN0 Min: 18*C Max: 18*C
TMPIN1 Min: 39*C Max: 54*C
TMPIN2 Min: 30*C Max: 35*C
CPU:
Core #0: Min: 40*C Max: 72*C
Core #1: Min: 43*C Max: 71*C
Core #2: Min: 46*C Max: 73*C
Core #3: Min: 39*C Max: 69*C
Package: Min: 46*C Max: 73*C
GPU:
TMPIN0: Min: 28*C Max: 45*C
Also, the PSU is Rosewill RP600V2-S-SL 600W
I used to have windows 8 on this computer and I could play borderlands 2 on it perfectly but with my windows 7 it isn't working.
I have a found a solution to this which I found at
http://steamcommunity.com/app/49520/discussions/0/864971765498062246/
where you run borderlands 2 from Borderlands2.exe not launcher.exe
