On Tue 28.2.2017 17.23.12 your computer crashed
crash dump file: C:\Windows\Minidump\022817-26890-01.dmp
This was probably caused by the following module: dxgmms2.sys (dxgmms2+0xB62C)
Bugcheck code: 0xD1 (0x10, 0x2, 0x1, 0xFFFFF809E07DB62C)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\drivers\dxgmms2.sys
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: DirectX Graphics MMS
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
On Fri 24.2.2017 14.29.33 your computer crashed
crash dump file: C:\Windows\Minidump\022417-30109-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x6BB153)
Bugcheck code: 0x124 (0x0, 0xFFFF970E1392E8F8, 0x0, 0x0)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\ntoskrnl.exe
description: NT Kernel & System
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might also be caused because of overheating (thermal issue).
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Fri 24.2.2017 3.04.56 your computer crashed
crash dump file: C:\Windows\Minidump\022417-26312-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x14A6F0)
Bugcheck code: 0x50 (0xFFFFFFFFFFFFFFFF, 0x0, 0xFFFFF800A649DA92, 0x0)
Error: PAGE_FAULT_IN_NONPAGED_AREA
Bug check description: This indicates that invalid system memory has been referenced.
On Thu 23.2.2017 23.31.02 your computer crashed
crash dump file: C:\Windows\Minidump\022317-26812-01.dmp
This was probably caused by the following module: hidusb.sys (hidusb+0x11EE)
Bugcheck code: 0x1E (0xFFFFFFFFC0000005, 0xFFFFF800B33011EE, 0x0, 0xFFFFFFFFFFFFFFFF)
Error: KMODE_EXCEPTION_NOT_HANDLED
file path: C:\Windows\system32\drivers\hidusb.sys
description: USB Miniport Driver for Input Devices
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
