boss amp problem
Colin_9
i just bough a boss r1100m amp. everything works but the remote to adjust the sub bass output from inside the car. i did notice the plug in on the amp is a little loose. is there anyway i can fix this problem?
what are you running? you wont see even 500 real watts out of that amp let alone 1100. return it and buy something decent.
rule of thumb is about $1 a watt. dont get a "max" amp.
im running a kicker comp r. i bought this amp many times for family and friends and they all work perfectly
