both audio jacks give off static noise
vamplord1122
I have the Asus CM1735 and both audio jacks give off static noise but you can still hear the music. its not the headphones because multiple headphones do the same thing and i think its internal because both the front and rear jacks do it.
under windows sound control and realteck audio control are the volume set to mute where the audio output is so low you cant hear it.
have you tried the newest audio drivers?? if your mb is a few years old the audio chipset may be going bad.
the audio stops and gos periodically and kind of sounds like a crackle with an electrical buzz but im not sure i understand your question
