Bottleneck help :3
Tathaga
49
i have athlon x4 635 and 2*4gb ripjaws
my currert gpu 460 hawk fans juz died, so i plan to buy new gpu
which gpu can i use so it wont get bottlenecked by that stupid cpu
choices are :
1. 7850
2. 660ti
3. 7950
PS. i dont oc
Well for starters, if the 460 you had was bottlenecking your cpu, these other three cards are going to bottle neck even worse. I would suggest you looking into a newer cpu. Theres a few good choices with the amd platform that wont choke up on a newer gpu.
i dont know if that 460 hawk was bottlenecking my cpu or not , but its fans broke. :'(
if my cpu doesnt bottleneck 7850 then i wud go for it , else i hafta buy i5 and waste my money :'( which i dont want
extremely sorry , but u can close this thread now , i had little time to decide and i have decided on 7850
sorry again :3
