Hi Fellas, its my first time posting here and just from reading around a bunch of other posts I'm still unsure of what components to use in my new rig. I'm planning to sort of have a hybrid machine for both gaming, video editing, rendering, and productivity needs. After further research I'm unsure whether I should switch platforms and build off an Intel CPU or just upgrade to an FX. Performance is a big issue here as I'm planning on having a sli/crossfire config in the future and don't want to bottleneck. Also, I hope to keep a budget of under $230 for the CPU, and I'm sure I can pick up an Intel Mobo for around $150-$180 if Intel would suit my needs. I also plan to overclock the CPU.
My current specs are:
AMD PHENOM X4 II 840 Black OC'D 3.78ghz (I know its pretty old and not worth overclocking but I did it anyways)
ASUS M5A97
AMD RADEON 7850
8GB Mushkin DDR3 RAM
This is working great for me now, but I really want to get better performance and build a higher end PC from the mobo. I would really Like to build a pc that averages 60+FPS in DX11 games and ultimate settings.
While I was looking at CPUs with my budget here are the ones that caught my eyes:
AMD FX-8350 $190-210
Intel i5 3570k $200-215
Intel 1155 Motherboards:
ASROCK Extreme4 $120-$140
ASUS P8Z77 $120-$200 (Probably aiming for a pro or deluxe for oc ability)
The reason I'm posting this is because I'm really quite unsure which way to go with it because I want to build off a budget but I have a little bit of cash to spare (not to much) for performance. So I was wondering if anyone else had some better ideas or builds to throw at me with the budget and mindset that I'm aiming for.
ASUS M5A97
AMD RADEON 7850
