[SOLVED] Bottom fan mounting concern
matatiesa123
24
So, I have a pretty bad case that has 2 bottom fan mounts, but behind them(if I mount them to push air into the case) is just the case floor, the only intake grill is between the both fan mounts. If I put fans there, would they be useless or would they help with temperatures? Really need to add fans to my case because my idle temperature is like 44°C, so I was wondering if mounting fans at the bottom would be useful for me. I am already planning on adding a front fan and an exhaust fan. These 4 are the only fan mounts that I have. Thanks in advance!
