Bottom power supply - Is that OK?
rogerthatman
29
Hi,
So I just bought a new computer without really know the power supply and after order and get it from the store, I've noticed the fan of the power supply is actually facing from the bottom of the pc case, is that normal? isn't it too hot down there or some?
The power supply should be great though - Corsair GS600 14cm Fan..
That is correct, the fan is supposed to be pointed downwards. It is nothing to worry about, because if it were pointed upwards it would output hot air into the case and increase temperatures.
rogerthatman
29
Yeah, but it seems that the hot air doesn't really have a big space to go out to.
