From where did you purchase your braided cables? Are they specific for the make/model of your PSU?
Cablemods is a reliable vendor and they produce excellent products. It isn't clear from your response whether these cables were designed to work with your PSU make/model. PSU cables can vary widely in how they are wired, even if they use what appears to be a common connector (on the PSU end).
If they were designed for your PSU, they should work. However, it seems that you bought two cables (for your GPU) and they are wired differently. Is that correct?
They should be okay to use then.they ask you these questions my friend but you choose manually from a list, the 2 cables are the same gpu end 8 pin and psu 6 as shown which will go to an 8 pin psu connection
