Archived from groups: alt.comp.periphs.videocards.ati (
More info?)
Ram is expensive right now, and 512mb is enough for all games out at the
moment so I wouldn't recommend adding any. I'm doing finw with 512mb in my
xp3200/9800pro system, and I play 1152 4xaa/8xaf for my games with no
problem. you can edit the config file to make games use more meomry in some
games, CoD for ex. I set it to take 256mb ram, it only took 128 for video
by default. Set "hunkmegs" higher in the config file, use notepad to do it.
That board is slower than the nfs boards, I'd sell the whole thing and get a
new board.ram (pc3200) and cpu when possible, all seems to be well balanced
at the moment.
Mike
"We Live for the One we Die for the One" <Mr fred@yahoo.com.au> wrote in
message news:0200b01v71ts2ljsantlqfq3kn6s7gkuee@4ax.com...
> Max you can go is Xp 2400,2600 266mhz if you can find on ,i think,
> unless your board is 333 ? then xp 2800 or whatever your boad maxes
> out at with your current bios upgrade
> Knock another half gig in and you should be set for a few years, best
> you can do with your system i think.
> Is your board a 333 or 266 bus system, if its 333 stick in 512k pc2700
> ram not sure if that will make it any speedier or not some other
> people will help, they are helpfull here
> Ive done what i can
> See ya.
> On 23 May 2004 05:27:00 -0700, transgression@hotmail.com (Sam) wrote:
> >Hi folks,
> >I bought a 9800pro 128MB at a good price. The rest of my system is:
> >xp1800 (overclocked to xp2000 speed)
> >K7S5A
> >512MB PC2100.
> >What's the best way to upgrade the rest of my system so everything is
> >evenly matched? Price is an issue!
> >Thanks!
> >Sam
