Bought a R9 280, have a Corsair CXM 750W modular - need power cables
harrisonharry
5
Hi crew,
I have bought a R9 280 (absolute bargain on Amazon at the moment, £132), and I have a modular Corsair CXM 750w power supply, however the extra cables seem to have gone missing - is there anywhere I can buy these cables?
I need one 6 pin PCI-E express cable to fit into both my power supply and the card, and one 8 pin.
I am located in the UK.
Thanks!
Yes.
You can buy two cables, if you want to. That's your decision to make.
Yeah I have managed to lose the original PSU ones, so with one of these cables I can connect my GPU? It says it requires 1 6 pin and 1 8 pin, which clearly this cable has, so just one will be enough?
Yes.
