Brand for case fan
CoolerMaster fans perform very well for the price.
Antec too.
Better quality fans are Enermax,Scythe,and Thermalright.
Noctua are good but overpriced i'd buy the above 3 for half the price.
lookerup
1,296
mobo: 970 extreme 3
cpu: amd phemon II x6 1075t
gpu: radeon hd 6850
hdd: 500 gb seagate barracuda
ram: 4gb ddr3 1333
psu: corsair cx600 v2
the cpu temperature is going over 40c which should not be happening and im trying to keep it between 35 ~ 40C
lookerup
1,296
I have that case with this cooler.
Comes with a tube of paste.
COOLER MASTER Hyper 212 Plus
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
http://us.ncix.com/products/?sku=41337&vpn=RR%2DB10%2D212P%2DG1&manufacture=COOLERMASTER&promoid=1141
And if you're using that case stock with only the 120mm front exhaust,you need to add at least a 120mm rear exhaust.
Better if you bought two,another for top exhaust.= what i did.
These!
COOLER MASTER R4
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103060
http://us.ncix.com/products/?sku=42176&vpn=R4%2DL2R%2D20AC%2DGP&manufacture=COOLERMASTER
lookerup
1,296
i actually did add two 120 mm fans in the rear but their stock fans. that was why i was asking for fan brands.
is there anything smaller than that? and requires less work? dont want to take out motherboard and put it back again.
