Brand New Built PC Won't Send Signal to Monitor
Chrono948
I built my PC last night and set up Windows at my club. I took it home AN HOUR LATER, set it up, and went to install my drivers. I didn't get a signal on my monitor. I tried about 8 times and then gave up cause I was tired. I woke up the next day and deside to try using an hdmi cable to my tv. Still no signal. Can someone please help?! Everything I try doesn't work!
I've connected through the motherboard with both the hdmi and the vga cable but I didn't know you could connect to the gpu. I have an nvidia 670. How would I connect it? Should I try taking it out and putting it back in?
with the pci-e gpu in your machine is defaulting to the gpu... you NEED to plug the monitor cables into the back of the gpu not the back of the motherboard.
