Hey everyone, I am fairly new to PC building is this my first real attempt at such a feat. I am having some real trouble getting my PC to boot and/or display on my monitors.
Here are my components:
CPU: Intel Core i5-4690K (desktop)
Motherboard: ASUS Z97-E
Graphics Card: EVGA GeForce GTX 960
Memory: G.Skills DDR3-1600 (2 x 4GB)
Power Supply Unit (PSU): Corsair CX-600M (500 watt)
Case: Cooler Master 912 HAF
Monitor: Samsung SyncMaster 204B (at least 6 years old)
Here’s my checklist
1. Read the motherboard manual twice.
2. Ensured the 8 pin CPU connector is plugged in to motherboard. This cable is straight from my PSU. Also ensured the 24 pin ATX power cable is also plugged in.
3. I did find an incorrectly placed standoff when I took off the motherboard. Tried to reboot and was much more successful in the boot process but still no display and still a solid red power LED light. Also confirmed nothing else is touching the back of the motherboard.
4. Graphics card is seated properly, heard the “notch sound” and the clasp popped into place on the motherboard (verified placement with motherboard manual).
5. My graphics card only as one power connector – ensured that it is plugged in directly to the PSU. Fans do turn on. The 6+2 pin cable converts to an 8 pin cable end to the PSU (all are in).
6. Have not tried booting with just one stick of RAM yet.
7. Yes, all the RAM sticks are in correctly – they clicked into place and are secure.
8. I have tried slots 1 & 3 and also 2 & 4, nothing has worked. I’ll try the one stick of RAM in slots 1, 2, 3 & 4 to see if this remedies the problem.
9. Plastic guard is off.
10. After the first round of failures, I did re-check the CPU and it did become misaligned. I fixed the problem and centered it. I need to make sure I have the notches in the correct direction.
11. I need to verify there are no bent pins on the CPU.
12. I am using the stock cooler.
13. The CPU fan is plugged in because it does turn on and rotate.
14. Do not see any foreign material in the thermal compound. Ensured all the fans are pushed through the motherboard properly – I can see them behind the motherboard.
15. Other Notable items:
a. I am using old monitors: (2) Samsung SyncMaster 204B’s to be exact. They have had difficulty in the past with recognizing video inputs/outputs. Would age be a factor? I have tried VGA, DVI, and hooked up a DVI cable to a DisplayPort adapter and still nothing. I have not tried an HDMI cable because I’ve read this is not as reliable. I am working on getting a different monitor to test.
b. Sometimes when I push the power button the fans of all the components do not turn on immediately and after a few second everything will click on.
c. I will test to see if the outlet I am using is not stable enough by plugging into a surge protector.
d. There may be a compatibility issue with my ASUS Z97-E and Intel i5-4690K processor. I am following up with ASUS to see if that is the case. PCPartPicker did not post any compatibility issues when I built – not that means its 100% compatible.
e. I do not have a DVD or hard drive plugged into the motherboard and have not tried as I have read and am aware neither are required to post and boot.
f. The LED power light has never been any different than red since I first started to boot.
g. I have tried to reset the jumpers but I have no idea if I did it correctly or if it even worked.
h. On PCPartPcker, the estimated wattage is around 315W and my PSU is 500W – I am assuming that is enough, but can someone confirm that?
Here’s my checklist
