[SOLVED] Bricked my mobo. Need parts advice
Dec 16, 2021
4
Bought a pre-built system 4 years ago and recently bricked my Asus B350m-a trying to do a bios upgrade. It is a microAtx
Has Ryzen7 2700x cpu with cooler
Geforce rtx 2070
16gb ram 2333
Windows install was on a 500gb ssd
Also has a 1tb hd
Well reading many threads here I would like to upgrade the cpu and motherboard. Keep the GPU for now. Possibly add a new ssd or better because it will probably need a new windows purchase??
Should I upgrade the case to ATX or just swap in a new motherboard and cpu? How much improvement can 1000$ get me gaming wise? Should I go cheap 500$ to keep most of my current rig and do a new purchase 1-2 years from now?
Make and model of your power supply? As you have a pretty competent GPU, and given the current situation, it wouldn't be a bad idea to start fresh, and just reuse the GPU, and maybe your storage.
PCPartPicker Part List
CPU: Intel Core i5-12600K 3.7 GHz 10-Core Processor ($299.98 @ Newegg)
CPU Cooler: ARCTIC Liquid Freezer II 240 56.3 CFM Liquid CPU Cooler ($87.98 @ Newegg)
Motherboard: Gigabyte Z690 UD DDR4 ATX LGA1700 Motherboard ($199.99 @ B&H)
Memory: Crucial Ballistix 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory ($118.99 @ B&H)
Case: Cougar MX330-G Air ATX Mid Tower Case ($54.99 @ B&H)
Power Supply: SeaSonic FOCUS Plus Platinum 850 W...
Geforce rtx 2070
16gb ram 2333
Also has a 1tb hd
Do you have original CD that came with MB and a CD/DVD player ? If you start with it inserted, after couple of tries it should accept original BIOS file that is on it.
Power Supply: SeaSonic FOCUS Plus Platinum 850 W 80+ Platinum Certified Fully Modular ATX Power Supply ($125.99 @ Newegg)
Total: $887.92
Generated by PCPartPicker 2021-12-17 09:51 EST-0500
Total: $887.92
I was wrong on 2 items in my setup. First the ssd is only 240gb, and next the ram is 2 8gb Adata DDr4 2666(19)8gx8u-dimm 1.2v
Finally the power unit is
High Power 600w
Hp1-J600gd-f12s
Thankyou for your reply and time
