bridge wired connection to tp-link 841nd
ng80092a
37
Hi,
I have 2 wireless lans created by 2 tplink routers cable-connected to my modem
http://puu.sh/7e4rV.png
They work perfectly fine, but since the wireless lans created are different, i can't remotely-anywhere from one wlan to another...
I know that i can solve this if one of the tplink routers is bridged into the modem, because the modem has a wireless lan himself, and i will be able to access it from one of the others wlans. (i've done that with a previous router)
The question is.. how can i wire-bridge one of the tplinks? (wireless bridge is too slow and doesnt get decent speeds).
Thank you
for anyone with the same problem here's the solution
You can use a wire to connect your bridged router.
However you have to connect the bridged router at one of the LAN-ports and leave the WAN-port unconnected.
Give this router an IP-address in the range you are using, but outside of the DHCP range of the primary router.
Also take care that you only activate DHCP on the primary router and disable it on the bridged router.
