I'm in Japan and plan to have my desktop shipped over soon. American outlets are 120 V, but in Japan they're only 100 V.
My PSU is the Cooler Master Hyper 212 Pro.
It's rated for 100-240 V so it should work, but as a novice in computer I just wonder if there is some hit to performance or if the change in voltage affects anything really. Does it?
Also, there is pretty much no grounding here. Would using some 3-to-2 cheater thing cause any issues, aside from the danger of not being grounded? I mean, some things have grounding in the form of these little green/yellow wires,like this:
However, theyre pretty much only for big appliances like refrigerators, washers etc, and because of that the only outlets with sockets for these little grounded...things are in the kitchen or laundry room or whatever. 95% of outlets are just 2-prong sockets:
Examples of plugs I'm considering:
Shockshield Yellow Portable GFCI Plug with Surge Protection
and this...
As I understand it, the third ground prong is just for grounding and not related to power supply. On a semi-related note, surge protectors pretty much must have grounding right?
and this...
