Broke one of the fans installed inside my case, looking for a replacement!
Stratosfear
Commendable
May 16, 2016
33
Hi guys I accidentally broke one of my fans inside my case.
The fan was sucking air in from the back of the case on the left of the mobo, if that makes sense.
My case is a Zalman Z11 and the fan that I broke looks like this https://imgur.com/a/Umb9LnC
I'm looking for a great replacement fan that is preferably white.
That looks like a standard 120 x 25mm fan.
You can buy any replacement you want.
Verify that the replacement has the proper connector which is likely to be a 3 pin connector.
