I broke cpu power cable thats connected to the unit. on my Antec 750w HCG-750M the PSU is modular can i get a replacement cable or do i have to get a new psu
Soldered i guess its the one thats connected with the motherboard 24pin powerI don't know. Is this CPU cable soldered to your power supply or is it a modular cable?
If it can't be taken out of your power supply, if it's not one of the cables that can be removed and put back in at will, then you're out of luck. 🙁Soldered i guess its the one thats connected with the motherboard 24pin power
It’s semi modular. 24 pin and CPU power are not modular everything else is...So is this modular or not? You describe it as modular at the top and then say the CPU cable is soldered to the power supply. If you have a 750M, it should be a modular power supply.
Yeah this is a Semi-Modular PSU. Since the 24 pin cable is soldered you have to replace the unit.
Just wanted to make sure as the HCG series has had, over the years, a modular, a semi-modular, and a non-modular.
