So I broke my headphone jack after tripping over the cable from my headphone while it was plugged into my headphone jack. (don't worry doc says I'll be fine). The problem is that it won't hold in the 3.5mm wire and it will just fall out, if I hold the wire in a certain position it still works. I see about 2 ways of fixing it; gluing all the plastic bits back together or buying a new part. I don't know what part it is I need to buy and also the cable attached to the chip (right term?) is not so easy to unplug. The case is a Fractal Design ARC Midi R2.
The one on the right is broken. Is this fixable? Can I buy this part? Hope you can help as I used this jack everyday and can't really listen to audio with it broken right now. Thanks for the help!
