Hey guys, had a bit of a snafu tonight as I was trying to get the M.2 standoff out my MB, Basically, I had a bit of an accident (was too aggressive/rushing) and managed to break the base off of the M.2 standoff from the MB.
Not sure what to do or how to fix it. The standoff's base still seems to sit in the MB if I push it in, and then I can screw the standoff into the base gently by hand, and then plug the NVMe drive into the MB and secure the NVMe drive with the screw into the standoff, but if I pull the drive a bit, it pops out as the standoff base is uprooted from the MB. I tried pushing it in again, and this time it seems to stay there even when slightly pulling the NVMe drive upward (I didn't trying pulling hard, just a slight amount of pressure to see if it's secure). Do you think it would be safe if I tried booting up/using the system in the off chance the NVMe drive's standoff uproots itself from the MB while in operation?
I was thinking of trying to glue it, but not sure what glue to use and also I was worried that I might get some glue on the MB and it's hard to get it back in the hole, didn't want to get risk getting glue on the MB's PCB. Would that cause any damage to the MB if I were to get glue on it?
Here are some photos I took. You can see in the photos the 2280's SSD standoff base has completely come off of the MB:
