Question Broken SATA connector on my 16TB Seagate drive - Best way to fix?
Jan 30, 2025
My daily driver started having issues, so I was going over all the connections and I broke the SATA connector on the hard drive when I lifted the cage witihout disconnecting the too short cable I had on the drive. Should I replace the connector? I found some used ones on Aliexpress.
Picture of the damage, please.
"Should I replace..."
Are YOU capable of soldering on that level?
Is there a known good backup of all data on this drive? (if not, why not)
