Broken USB 3.0 pins! HELP!
Visiionz
Commendable
Sep 17, 2016
28
Hi guys!So I was trying to build my first PC and everything was going really well. Actually I built it! I just wanted to mess with the cables to have a better cable management. Any way I unplugged my USB 3.0 cable from the USB 3.0 port on the motherboard and routed the cable the way I wanted and when I plugged the cable back to the USB 3.0 port on the motherboard I wasn't able to plug it so I pushed it hard but accidentally broke the pins on the USB 3.0 port on the motherboard and some pins were badly bent actually some fell down. Help! Please guys I need some help if there is an adapter that I can use or something else please link it .I actually saw some kind people saying that I can use this adapter Inateck PCI-E to USB 3.0 5-Port PCI Express Card and 15-Pin Power Connector. This is the link https://www.amazon.com/gp/aw/d/B00FPIMJEW/ref=mp_s_a_1_3?ie=UTF8&qid=1474141136&sr=8-3&pi=SY200_QL40&keywords=inateck+20+pin&dpPl=1&dpID=517We2KgceL&ref=plSrch . But Can I use my 3.0 ports on my case?There is 2 USB 3.0 ports on the front of my case and 2 more USB 3.0 ports on the back of the case and there is 2 more USB 2.0 ports on the back too. But I want all my case USB ports to function properly. Even if all USB ports will become 2.0 ports not 3.0. Please guys I need some help.Link me a product if that will fix my problem. Please leave a link and your Email to easily contact each other. PLEASE HELP ME GUYS! Thanks
Dude seriously.
I have a motherboard that only has usb3 on the rear & has no USB 3 headers.
My case (a Silverstone gd06) ONLY has USB 3 ports on the front.
I bought the anker card because my pcvia in an under TV cabinet & I have no access to the ports on the back without unplugging everything.
The anker card plugged into those front ports ia the only connection I use for portable hard & flash drives.
I plug & unplug drives a lot - this ia a htpc for video etc after all.
Not had a single issue in the 2 years + it's been in there.
Is it better than the inateck ?? No idea never heard of them .
The anker is tiny though , works perfectly & I have no hesitation in recommending it at all.
But does all 3.0 ports work perfectly if I plugged the 3.0 cable to the 19 pin port on the card?
The port will run 2x case USB 3 ports .
Had speeds of up to 160mbs on a portable usb3 drive - generally 90-140mbs though depending on amount if small files etc.
So yes it works perfectly , I've filled a 2tb external drive copying from internal in under 2 hours in the past.
But which one you think is better? The anker one or the Inateck one? For the bang for your buck? PLEASE BRO TELL ME. but are you sure that both have 20 pin connectors? Please be sure cuz I am dam serious. Thanks.
Dude seriously.
