BSNL broadband wifi connection problems
333rupesh
5
Hello,
I have recently switched on to BSNL broadband and I have UTSTARCOM WA3002G4 ADSL modem + wifi router. I have done the usual procedure of setting up broadband and wifi by logging in to 192.168.1.1 by connecting ethernet cable to my laptop. The wired internet and wifi were working fine after i set up for the first time, but when I unplug the LAN cable from my laptop and restart my modem by pressing the power button (with LAN cable still unplugged), all my devices are not detecting the modem. In this case each time when there is a power outage/ maual restart of the modem, I manually login to 192.168.1.1 by reconnecting the lan cable to my laptop and click Save/Apply in Wireless - Basic settings and then my wifi connection shows up.
I need some help to skip this manual Save/Apply each time.
Please help me on this.
Thanks in advance
@ingtar33: I tried resetting the clock now, but this didn't help in resolving the problem 🙁
can you provide me some links where i can get this firmware. I have searched a lot over google but found it no where
My modem model is UTSTARCOM WA3002G4
I tried this too... again have the same issue of manually applying the settings after i restart the modem.
