Question BSOD analysis help
xRatspike
31
SPECS
  • Amd Ryzen5 3600
  • Gtx 1660ti 6gb
  • 32 gb ram
  • Asus B450-F Mobo
DUMP
https://drive.google.com/file/d/1ptFcmg-TrX5NrgqLIYaSD8rENhUYAJGz/view?usp=sharing
For some reason, my computer fails to create minidump files. I have tried to fixing this in settings as it was originally turned off, however, upon turning it on it only creates large dump files named as minidump files. I threw the dump file into windows debugger and have attached the .txt file. I am not sure what any of it means and would appreciate any help! This BSOD comes at random and I cannot seem to recreate the problem. Temps are fine and I ran sfc, memtest, and chkdsk mutliple times with no problems.
That RAM should be running at 3200MHz. Obviously running RAM at 2133MHz is probably not your issue here but go in your BIOS and turn XMP/DOCP profile so that your RAM run at 3200MHz.
Is that a 4x8GB RAM Kit or a 2x16GB RAM Kit? If it's 2 sticks are they in the A2-B2 slots on your board?
xRatspike
31
Will do, it is a 2x16gb and they are in A2 and B2 on the board!
