BSOD and static sound after a 10-60 minutes of gaming
gabtob
Hi,
I hope this is the right category. Its my windows 10 pc crashing while gaming. My PC crashes completely and I need to restart it by holding the restart button around 10-60 minutes after i launch a game.
The event viewer gives me 4 errors that pop up consistently just prior to the crash. Here they are:
First error: Application Popup Event ID 1060
The description for Event ID 1060 from source Application Popup cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
\??\C:\WINDOWS\SysWow64\drivers\SECDRV.SYS
the message resource is present but the message is not found in the string/message table
Second error: Service control manager Event ID 7000
The SecDrv service failed to start due to the following error:
This driver has been blocked from loading
Third error: DistributedCOM Event ID 10016
The application-specific permission settings do not grant Local Activation permission for the COM Server application with CLSID
{6B3B8D23-FA8D-40B9-8DBD-B950333E2C52}
and APPID
{4839DDB7-58C2-48F5-8283-E1D1807D0D7D}
to the user NT AUTHORITY\LOCAL SERVICE SID (S-1-5-19) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
Fourth error: Same as third error, same second. It alwasy appears twice.
Any help is very appreciated!
a machine can have various sound drivers installed.
motherboard sound driver, cpu built in GPU has a sound driver, a add on GPU will have a sound driver.
you can also have sound drivers attached via Bluetooth and by USB and add on sound cards.
most motherboard vendors updated the motherboard sound driver after windows 10 shipped. some did not bother to update the driver and you have to go to the chip vendor to get updates.
update the motherboard sound driver from the motherboard vendors website. It is pretty common for the windows 10 provided sound driver to conflict with the graphics drivers sound support. Most motherboard vendors did a update right after windows 10 shipped.
otherwise you would have to provide the minidump files from c:\windows\minidump directory.
most of the errors you listed in the eventlog are not related to any bugcheck. (just common stupid little bugs that were not fixed before the system was release. everyone gets them in the event logs)
Hi thanks for the answer.
So this sound driver is separate from the BIOS driver or the realtek drivers? Because those are up to date. Its an rsrock z77e-itx.
And are you sure they are not the cause of the crash even tho they are alwasys listed in the same order in the last few seconds before the crash?
