I got BSOD randomly after I play Game, it doesn't happen during or before, but just after. It has been happen ever since I update the GPU and Factory restore my computer. One just happen right now : I turn on youtube to watch video and I turn on a game, then I alt tab out of game right after it launch to continue to watch youtube - It crash right after and this is the dump file it came with:
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 3B, {c0000005, fffff80002c885fe, fffff880088870b0, 0}
Probably caused by : cdd.dll ( cdd!DrvAssociateSharedSurface+7b )
Followup: MachineOwner
1: kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff80002c885fe, Address of the instruction which caused the bugcheck
Arg3: fffff880088870b0, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
FAULTING_IP:
nt!ExEnterCriticalRegionAndAcquireFastMutexUnsafe+26
fffff800`02c885fe f00fba3100 lock btr dword ptr [rcx],0
CONTEXT: fffff880088870b0 -- (.cxr 0xfffff880088870b0)
rax=fffffa8006bcfa60 rbx=0000000000000000 rcx=0000000000000000
rdx=0000000040002200 rsi=fffff900c2641030 rdi=fffffa8006bcfa60
rip=fffff80002c885fe rsp=fffff88008887a80 rbp=0000000000000000
r8=ffffffffb1121700 r9=0000000000000040 r10=00000000034af9a0
r11=fffff88008887b08 r12=ffffffffb1121700 r13=0000000040002200
r14=0000000004d6cf20 r15=0000000000000001
iopl=0 nv up ei ng nz na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010286
nt!ExEnterCriticalRegionAndAcquireFastMutexUnsafe+0x26:
fffff800`02c885fe f00fba3100 lock btr dword ptr [rcx],0 ds:002b:00000000`00000000=????????
Resetting default scope
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x3B
PROCESS_NAME: dwm.exe
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from fffff960006d6d3f to fffff80002c885fe
STACK_TEXT:
fffff880`08887a80 fffff960`006d6d3f : 00000000`00000000 00000000`00000000 ffffffff`b1121712 00000000`00000020 : nt!ExEnterCriticalRegionAndAcquireFastMutexUnsafe+0x26
fffff880`08887ab0 fffff960`001dd365 : 00000000`00000000 fffff900`c2692460 00000000`034afa40 00000040`00000230 : cdd!DrvAssociateSharedSurface+0x7b
fffff880`08887b10 fffff960`00200749 : 00000000`00000001 fffff880`08887c60 00000000`034afa40 00000000`00008729 : win32k!GreSetRedirectionSurfaceSignaling+0x125
fffff880`08887b60 fffff800`02cbdad3 : fffffa80`06bcfa60 fffffa80`06bc51a0 ffffffff`fffd67f0 fffffa80`06bc51a0 : win32k!NtGdiHLSurfSetInformation+0x209
fffff880`08887be0 000007fe`ff6d4efa : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`034af978 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7fe`ff6d4efa
FOLLOWUP_IP:
fffff960`006d6d3f ba0c000000 mov edx,0Ch
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: cdd!DrvAssociateSharedSurface+7b
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: cdd
IMAGE_NAME: cdd.dll
DEBUG_FLR_IMAGE_TIMESTAMP: 4d3fbfc6
STACK_COMMAND: .cxr 0xfffff880088870b0 ; kb
FAILURE_BUCKET_ID: X64_0x3B_cdd!DrvAssociateSharedSurface+7b
My system currently is :
Window 7 Pro, 64 bit.
Bios Ver 6.05
Processor: Intel 2 Duo E7500 @ 2.93
RAM: 4GB
Display: NVIDIA Gefore GTX 750, 1 GB OC
PSU: Corsaic 430w
I believe all my devices are up to date except GPU, I am currently using the Driver that came along with its CD because I thought that the latest driver causes BSDO
Any help is appreciated,
thank you.
1: kd> !analyze -v
Arguments:
Debugging Details:
FAULTING_IP:
BUGCHECK_STR: 0x3B
CURRENT_IRQL: 0
STACK_TEXT:
FOLLOWUP_IP:
MODULE_NAME: cdd
IMAGE_NAME: cdd.dll
Bios Ver 6.05
RAM: 4GB
PSU: Corsaic 430w
thank you.
