BSOD Help! Can't Seem To Find The Cause.. ;[ Help
Falcon904
8
Hello,
I've gotten this BSOD earlier and was extremely curious on what caused it. I'm not that well with Analyzing and Debugging BSOD error codes etc. I decided to come onto here and ask for some help. I have the latest BIOS version, Latest video drivers etc. So i specifically have no clue on what caused this BSOD. I will post the Minidump file below to help out.
Here's a Screenshot of BlueScreenView program:
http://i.imgur.com/Nz4DghS.png
Here's a zip containing the Minidump:
http://fbe.am/qBX
Somebody please review the dump code! ;[
This may just help:
http://msdn.microsoft.com/en-us/library/windows/hardware/ff558949(v=vs.85).aspx
From this I would suggest updating graphics drivers, and if that doesn't sort it make sure that your page file settings are correct. Instructions below
To verify the page file size:
1. Hit the windows key & pause/break (Control Panel > System and security > System)
2. Click Advanced system settings on the left
3. Click settings under the performance section
4. Click the advanced tab, and click change at the bottom
5. Check the "Automatically manage paging file size for all drives"
I already have the "Automatically manage paging file size for all drives" ticked/enabled. All my video drivers are up-to-date. If another BSOD arrives, I will post the Dump file for further help, So we can see if the BSOD is the same cause. Thanks for advising and for the swift reply!
