[SOLVED] BSOD help, feels like I've tried everything. Crash dumps inside
Sep 2, 2021
Happens more often/faster when watching youtube videos. I've been at this for a couple days looking through google trying to find a fix and I can't seem to find anything
On Thu 9/2/2021 10:51:17 PM your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\MEMORY.DMP
This was probably caused by the following module: ntdll.sys (ntdll!ZwAlpcCreateSecurityContext+0x14)
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF8064247AD21, 0xFFFFF6829401E740, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: ntdll.sys .
Google query: ntdll.sys SYSTEM_SERVICE_EXCEPTION
On Thu 9/2/2021 6:02:35 PM your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\090221-7062-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x3F71D0)
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF80769A7AD21, 0xFFFFB2866A8763D0, 0x0)
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\WINDOWS\Minidump\090221-6046-01.dmp
On Thu 9/2/2021 9:34:54 PM your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\090221-6109-01.dmp
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF8074667AD21, 0xFFFF838C053F6800, 0x0)
On Thu 9/2/2021 8:59:15 PM your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\090221-6562-01.dmp
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF80733A7AD21, 0xFFFFF3857B39E800, 0x0)
I saw victims, thought... lan drivers
look at 1st dump.
afd.sys. Ancillary Function driver for Winsock - windows uses it to talk to lan drivers.
Seems to confirm that idea.
see 2nd crash... directx... hang on a moment
good thing top 2 showed some clues as other 3 BSOD less telling.
Do you use WIFI or Ethernet cable?
What Wifi card is it?
Jul 29 2019rtwlanu.sysRealtek WLAN USB NDIS Driver https://www.realtek.com/en/
if you use Ethernet there could be newer drivers
Sep 29 2020e1d68x64.sysIntel(R) Gigabit Adapter driver
mine are showing as 2021. Try running...
  1. Open Windows File Explore
  2. Navigate to C:\Windows\Minidump
  3. Copy the mini-dump files out onto your Desktop
  4. Do not use Winzip, use the built in facility in Windows
  5. Select those files on your Desktop, right click them and choose 'Send to' - Compressed (zipped) folder
  6. Upload the zip file to the Cloud (OneDrive, DropBox . . . etc.)
  7. Then post a link here to the zip file, so we can take a look for you . . .
Hi, I ran the dump files through the debugger and got the following information: https://jsfiddle.net/qbh198s7/show This link is for anyone wanting to help. You do not have to view it. It is safe to "run the fiddle" as the page asks.
File information:090221-7062-01.dmp (Sep 2 2021 - 18:02:35)
Bugcheck:SYSTEM_SERVICE_EXCEPTION (3B)
Probably caused by:memory_corruption (Process: LeagueClient.exe)
Uptime:0 Day(s), 0 Hour(s), 50 Min(s), and 37 Sec(s)
File information:090221-6562-01.dmp (Sep 2 2021 - 20:59:15)
Probably caused by:memory_corruption (Process: chrome.exe)
Uptime:0 Day(s), 0 Hour(s), 34 Min(s), and 50 Sec(s)
File information:090221-6359-01.dmp (Sep 2 2021 - 23:22:28)
Uptime:0 Day(s), 0 Hour(s), 28 Min(s), and 16 Sec(s)
File information:090221-6109-01.dmp (Sep 2 2021 - 21:34:54)
Uptime:0 Day(s), 0 Hour(s), 32 Min(s), and 43 Sec(s)
File information:090221-6046-01.dmp (Sep 2 2021 - 22:51:17)
Probably caused by:memory_corruption (Process: lghub_agent.exe)
Uptime:0 Day(s), 1 Hour(s), 13 Min(s), and 15 Sec(s)
Possible Motherboard page: https://www.asus.com/us/Motherboards-Components/Motherboards/PRIME/PRIME-Z390-A/
There is a BIOS update available for your system. You are using version 1502 and the latest is version 1802. Wait for additional information before deciding to update or not. Important: Verify that I have linked to the correct motherboard. Updating your BIOS can be risky. Never try it when you might lose power (lightning storms, recent power outages, etc).
This information can be used by others to help you. Someone else will post with more information. Please wait for additional answers. Good luck.
look at 1st dump.
mine are showing as 2021. Try running https://www.intel.com.au/content/www/au/en/support/intel-driver-support-assistant.html and see if its got any newer.
the Direct X crash is likely to be GPU drivers, very rarely is it audio.
try running DDU in safe mode, remove Nvidia drivers and reinstall them again - https://forums.tomshardware.com/faq...n-install-of-your-video-card-drivers.2402269/
