Hi Everyone,
I built a desktop a couple of years back (ASUS Motherboard, i7-2600k, M4 SSDm Secondary HDD, GTX 560 Ti) but have only been using it on and off as I was studying overseas. I've been using it this round since August, but have recently suddenly started getting BSODs everytime I used it.
The system boots as per normal but after a couple of minutes of use (it can vary from 10 minutes to an hour) it hangs and then crashes with a BSOD. I've enabled small memory dump in the hopes that it'll give me a better idea of what went wrong, but that only worked the first time: subsequently the computer just gets stuck on "Initializing disk for crash dump" even if left overnight.
I tried executing a system restore to a point earlier in December but that doesn't seem to have solved the problem.
Previously the BSOD listed different possible causes: once it was ataport.sys, then volmgrx.sys, then netbios.sys, amongst others. The most recent BSODs have not identifies a specific driver/process. The last one just indicates: "STOP: 0x000000F4 (0x0000000000000003, 0xFFFFFA80086E2B10, 0xFFFFFA80086E2DF0, 0xFFFFF8000FBD56D0)"
Any help would be greatly appreciated: or would my only option be a clean install (Would that actually help? Wouldn't want to do that unnecessarily)
Thanks in advance!
Thanks in advance!
