BSOD, help. :)
Vacka
293
Hey guys:) ,
So i just got a BSOD. Ive had them in the past sometimes for driver problems... amd drivers. And I got a BSOD yesterday I believe, and I ignored it, but today I got another one and I want to stop it from happening again in the future. If anyone knows what caused this BSOD and how to stop it from happening again please answer in this forum post. :) Here is the BSOD information:
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 4105
Additional information about the problem:
BCCode: 1e
BCP1: FFFFFFFFC0000005
BCP2: FFFFF800032F8622
BCP3: 0000000000000000
BCP4: FFFFFFFFFFFFFFFF
OS Version: 6_1_7601
Service Pack: 1_0
Product: 768_1
Files that help describe the problem:
C:\Windows\Minidump\080314-13197-01.dmp
C:\Users\Basile\AppData\Local\Temp\WER-50513-0.sysdata.xml
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Here is the dmp file: https://www.dropbox.com/s/ip5w92cr32r42e5/080314-13197-01.dmp
Thanky you guys. :) Please help.:) You are awesome. :) Lol. :)
Run Checkdisk/repair and sfc scanow (Google it) and a virus scan eg Avast and Malwarebytes.
Test your ram with memtest86. Check in Control Panel, Device Manager whether all your devices are working properly.
If no fix then
Post your build in detail including OS and
Download HWInfo and run Sensors then post the results - usually 3 screenshots in TinyPic or similar.
Can it be a bad oc? my specs are in my quote i believe. :) and I cannot really do the rest right now cuz i have to go so i will keep posting here tomorrow, srry. :) ty for the replies. :) and please be here tomorrow as well. :)
http://ca.pcpartpicker.com/parts/partlist/ <--- detailed build, the hard drvie is a seagate momentus xt 500gb hybrid drive, and my cpu is overclocked to 4.3ghz although I am thinking it may be a bad oc causing the bsods. As for memtest, how exactly do I use it?
This -
CPU: AMD FX-8320 3.5GHz 8-Core Processor ($159.99 @ NCIX)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.79 @ DirectCanada)
Motherboard: Asus M5A97 R2.0 ATX AM3+ Motherboard ($104.95 @ Vuugo)
Memory: Corsair Vengeance LP 8GB (1 x 8GB) DDR3-1600 Memory ($70.48 @ Newegg Canada)
Video Card: Sapphire Radeon HD 7770 GHz Edition 1GB Video Card ($235.38 @ Amazon Canada)
Case: Thermaltake VL80001W2Z ATX Mid Tower Case ($32.50 @ Vuugo)
Power Supply: Corsair Builder 600W 80+ Bronze Certified ATX Power Supply ($79.98 @ Amazon Canada)
Optical Drive: LG GH24NSB0 DVD/CD Writer ($16.99 @ Canada Computers)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) ($99.79 @ DirectCanada)
Monitor: Asus VS228H-P 21.5" Monitor ($149.98 @ Newegg Canada)
Wireless Network Adapter: D-Link DWA-548 802.11b/g/n PCI-Express x1 Wi-Fi Adapter ($29.99 @ Amazon Canada)
Total: $1009.82
yup
I am going to run memtest now, but When I run memtest do I take a picture to send to you, or what? What do I look for in memtest?
I have a seagate momentus xt 500gb hybrid drive for my hdd, and to reset bios/cmos can i just use the clear cmos button on my motherboard?
srry havent cleared the cmos yet ive been obsesed with wow, I got another blue screen just like 4 minutes ago, : Problem signature:
Locale ID: 4105
BCCode: 1e
BCP1: 0000000000000000
BCP2: 0000000000000000
BCP4: 0000000000000000
Service Pack: 1_0
Product: 768_1
C:\Windows\Minidump\080714-12589-01.dmp
C:\Users\Basile\AppData\Local\Temp\WER-118794-0.sysdata.xml
that is the info tell me if ud like the dmp file. :) ty again i7 baby 😀.!
-check you cpu speed and disable the overclock to see if it is the cause.
(cpu = 3.5 GHZ with 4.0GHz turbo but reported running at 4.3GHZ via BIOS?)
system bugchecked waiting for access to a protected resource. either a driver screwed up or memory for the driver was messed up by corruption.
I would run memtest86 and confirm your hardware was ok, then I would start removing some of your more questionable drivers.
I would also run malwarebytes to make sure you don't have malware corrupting memory.
I would look to see why you appear to have two copies of a graphics overclocking software running at the same time.
(I would remove them both, other drivers are listed mainly because of the age and that they are 3rd party)
also, you should update your chipset drivers for your cpu to get better USB support. some of the older usb network drivers tended to corrupt memory when used with outdated chipset drivers. (and update \SystemRoot\system32\DRIVERS\Dnetr28x.sys Thu Aug 23 20:40:11 2012 if you can find a new driver)
memory dump:
AODDriver2 \??\C:\Program Files\ATI Technologies\ATI.ACE\Fuel\amd64\AODDriver2.sys Tue Feb 11 03:06:52 2014
AODDriver2_fffff8800587e000 \??\C:\Program Files (x86)\AMD\OverDrive\amd64\AODDriver2.sys Tue Oct 29 17:58:36 2013
\SystemRoot\system32\DRIVERS\InputFilter_FlexDef2c.sys Fri Aug 06 02:54:55 2010
\SystemRoot\system32\DRIVERS\MouFilter_FlexDef4.sys Tue Oct 19 19:58:43 2010
\C:\Windows\system32\Drivers\SYMEVENT64x86.SYS Tue Aug 21 22:33:18 2012
update ethernet driver
\SystemRoot\system32\DRIVERS\Rt64win7.sys Wed Dec 26 09:17:50 2012
\SystemRoot\system32\drivers\NISx64\1405000.01C\Ironx64.SYS Mon Jul 23 17:34:50 2012 (old norton driver???)
BIOS Release Date 04/07/2014
Manufacturer ASUSTeK COMPUTER INC.
Product M5A97 R2.0
Version Rev 1.xx
Processor Manufacturer AMD
Processor ID 200f6000fffb8b17
Processor Version AMD FX(tm)-8320 Eight-Core Processor
Processor Voltage 8eh - 1.4V
External Clock 200MHz
Max Speed 4300MHz
Current Speed 4300MHz
memory:
Speed 1600MHz
Manufacturer Corsair
Part Number CML8GX3M1A1600C10
