BSOD, I need help,what should I do?
SpicyMiller
19
So I have no clue as to what to do with my BSOD problems, which has happened 4 times now since the 11th but I downloaded bluescreenview which shows why you got BSOD & here's what it shows for the four BSOD.
BSOD list is old to newest:
INTERNAL_POWER_ERROR
IRQL_NOT_LESS_OR_EQUAL
KMODE_EXCEPTION_NOT_HANDLED - which someone said was a driver problem so I updated all of my drivers-
SYSTEM_SERVICE_EXCEPTION
So any idea on what I should do?
2.7GHz up to 3.2GHz AMD A6-4400M Accelerated Processor
AMD Radeon HD 7520G Discrete-Class graphics and up to 4077MB total graphics memory
8GB DDR3 SDRAM
I'm using Windows 8 by the way
No idea, I don't know much about computers to be honest
Restart your laptop, repeatedly press delete while the laptop is powering up until the BIOS interface shows. You should be able to adjust settings from there. Loos for power saving settings or something, There should be a number of them. Enable them then save and quit the set up. Boot your PC and see if the problem still persists.
