BSOD Irql not less or equal
sasakib13
8
Hi,
I AM GETTING THIS BOSD IRQL NOT LESS OR EQUAL error after some random time, have reinstalled windows, used without gpu no solve. Some time pc is OK for 3~4 hours then same again, is this a ram problem or gpu or bios, plus can't start high graphics game for this problem
Link
http://
Configure
I 5 3.2 ghz
Gtx 760
8 gb ram{4x2)
Tt 530w
Gigabyte z77
you would have to put the actual memory dump file on a server like microsoft onedrive, share the file for public access and post a link.
the memory addresses in the photo look like valid kernel memory addresses.
the system was trying to write to a virtual memory address from a driver (at some memory address, the last one in the list shown in the photo).
you might try and update your sata controller driver from your motherboard vendors website.
note: generally you want to update your BIOS and all of the motherboard drivers at the same time because some will come as a matched set. (I would skip utilities unless you actually use them)
if you post the memory dump, the driver list can be looked at and it might show the offending driver or a overclocking driver that could cause this problem.
Hi iknow it's a bit late but uploaded the files here
Link
http://
http://
