So this happened twice already to me, just this moment and yesterday.
Yesterday it happened when i was was supposed to click shutdown when it suddenly BSOD and showed the error code IRQL NOT LESS OR EQUAL
And the second one happening after i closed VALORANT and once i clicked on my Opera browser it BSOD
After the first BSOD i looked into the internet for some solutions and updated my windows and drivers.
After the second BSOD what i did was i did a Windows Memory Diagnostic test, and came out with nothing and normal system
I checked for the Event Viewer log for the specific time it BSOD earlier, and it showed
"The computer has rebooted from a bugcheck. The bugcheck was: 0x0000000a (0xffffb982ad779e63, 0x0000000000000002, 0x0000000000000000, 0xfffff8012ab11f34). A dump was saved in: C:\WINDOWS\Minidump\061321-11531-01.dmp. Report Id: 6900f948-d008-484b-a1da-8b4ac2a26ea0."
Will be attaching the minidump file at the bottom
https://1drv.ms/u/s!AnUU8guFS_5Par-AmzL7ZJPXz6A?e=oeUnDw
Any solutions to avoid this happening again in the future?
UPDATE: I did an "sfc /scannow" command in CMD and found a corrupt windows file. Checked the logs and it says "Repairing file \??\C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\\mscormmc.dll from store" and says that "Windows Resource Protection found corrupt files and successfully repaired them"
I dont know if this fixed the problem, but id be taking more solutions if ever it comes up
