Question BSOD IRQL_NOT_LESS_OR_EQUAL
Feb 11, 2019
Hello guys, so I"m having problems with my pc right now, I keep getting bsods with error code IRQL_NOT_LESS_OR_EQUAL. I think that I tried every solution I could find on internet, but none of them worked. I checked my memory with memtest and it showed no errors. The bsod happens randomly, while im gaming, working or just browsing net. Here is onedrive link to minidump folder and pc specs https://1drv.ms/f/s!AtOZybUDGkNbghTuzeujL7MecqCZ
Ocz 600w PSU
Asrock 970 pro3 R2.0
Amd fx8350
gtx 1050ti
16 gb of ram in dual channel
Thanks for any help.
Hi, I ran the dump files through the debugger and got the following information: https://pste.eu/p/KhSt.html
File information:021119-13312-01.dmp (Feb 11 2019 - 11:59:06)
Bugcheck:KMODE_EXCEPTION_NOT_HANDLED (1E)
Probably caused by:memory_corruption (Process: System)
Uptime:0 Day(s), 0 Hour(s), 04 Min(s), and 41 Sec(s)
File information:021119-11671-01.dmp (Feb 11 2019 - 12:16:42)
Bugcheck:IRQL_NOT_LESS_OR_EQUAL (A)
Uptime:0 Day(s), 0 Hour(s), 11 Min(s), and 30 Sec(s)
File information:021119-11609-01.dmp (Feb 11 2019 - 13:39:25)
Uptime:0 Day(s), 0 Hour(s), 39 Min(s), and 43 Sec(s)
File information:021119-11390-01.dmp (Feb 11 2019 - 12:41:03)
Probably caused by:ntkrnlmp.exe (Process: System)
Uptime:0 Day(s), 0 Hour(s), 17 Min(s), and 57 Sec(s)
File information:021119-11671-02.dmp (Feb 11 2019 - 12:58:51)
Uptime:0 Day(s), 0 Hour(s), 01 Min(s), and 50 Sec(s)
BIOS information was not included in the first dump file. This can sometimes mean an outdated BIOS is being used.
I can't help you with this. Someone else will post with more information soon. Please wait for more answers. Good luck.
Reactions: Colif
Alright thanks, I updated my bios with app shop from asrock website so maybe it will fix the problem. I will write if any bsod appears. Thanks for help again.
