BSOD Issue Help
ZeroGravity780
782
I have been having issues with windows 10. I upgraded to Kaby Lake in May and have had on and off issues. I have mem checked with no issues and stress tests show no signs of instability. I use Malwarebytes and windows defender which both never show any signs of virus. I have all my drivers up to date. My computer got the BSOD on Friday and was stuck in a loop of BSOD. Every couple try's it would work and I would try to reset windows only for it to fail. I reinstalled windows via USB and now it works okay. Yesterday ghost recon froze and resulted in a BSOD on restart but I have been playing Shadow Of War and other games with no issues. Ghost recon did have issues loading in the terrain which was black during the 5min of gameplay before it froze. PUBG is used to be another BSOD issue for me. I cant tell if its a hardware problem or software.
Please help.
Look at any recent change you have made before the BSODs. Try undoing it. Use one of the BSOD viewers. One simple test is to boot it in safe mode:
https://www.digitalcitizen.life/4-ways-boot-safe-mode-windows-10
Do you still crash? Most likely hardware.
If you don't crash? Most likely driver or other software.
BSOD viewer:
http://www.osronline.com/page.cfm?name=Analyze
http://www.nirsoft.net/utils/blue_screen_view.html
more info
https://www.raymond.cc/blog/how-to-analyze-memory-dump-dmp-file/
I will try these steps when I am off work. I will let you know what happens. Thanks!
