[SOLVED] BSOD issues please help
Dec 3, 2019
Getting random BSOD's please help.
Ran ram through the windows memory Diag for 8 passes extended and turned up zero errors.
Dump File : 120219-28171-01.dmp
Crash Time : 12/2/2019 9:31:57 PM
Bug Check String : SYSTEM_SERVICE_EXCEPTION
Bug Check Code : 0x0000003b
Parameter 1 : 00000000c0000005 Parameter 2 : fffff80313c66e1d
Parameter 3 : ffff860ad5a91ce0 Parameter 4 : 0000000000000000
Caused By Driver : nvlddmkm.sys
Caused By Address : nvlddmkm.sys+123df3
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : ntoskrnl.exe+1c14e0
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\120219-28171-01.dmp
Processors Count : 12
Major Version : 15
Minor Version : 18362
Dump File Size : 1,226,596
Dump File Time : 12/2/2019 9:38:28 PM
Dump File : 120219-28984-01.dmp
Crash Time : 12/2/2019 2:12:00 AM
Bug Check String : APC_INDEX_MISMATCH
Bug Check Code : 0x00000001
Parameter 1 : 00007ffbc4dbc864 Parameter 2 : 0000000000000000
Parameter 3 : 00000000ffff0000 Parameter 4 : fffff30f5b6d8b80
Caused By Driver : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+1c14e0
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\120219-28984-01.dmp
Major Version : 15
Dump File Size : 694,292
Dump File Time : 12/2/2019 2:17:11 AM
Dump File : 120119-28578-01.dmp
Crash Time : 12/1/2019 2:33:02 PM
Bug Check String : DRIVER_IRQL_NOT_LESS_OR_EQUAL
Bug Check Code : 0x000000d1
Parameter 1 : 00000000000051c8 Parameter 2 : 0000000000000002
Parameter 3 : 0000000000000000 Parameter 4 : fffff8057b1da113
Caused By Address : nvlddmkm.sys+6da113
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\120119-28578-01.dmp
Major Version : 15
Dump File Size : 1,106,316
Dump File Time : 12/1/2019 2:35:34 PM
Dump File : 120119-32281-01.dmp
Crash Time : 12/1/2019 12:08:10 AM
Parameter 1 : 00000000c0000005 Parameter 2 : fffff8074ec66e1d
Parameter 3 : fffffe0223a27ce0 Parameter 4 : 0000000000000000
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\120119-32281-01.dmp
Major Version : 15
Dump File Size : 800,908
Dump File Time : 12/1/2019 12:19:33 AM
Dump File : 112919-31890-01.dmp
Crash Time : 11/29/2019 12:15:28 PM
Bug Check String : MEMORY_MANAGEMENT
Bug Check Code : 0x0000001a
Parameter 1 : 0000000000041201 Parameter 2 : ffffef3ffe604b40
Parameter 3 : 0100000587117025 Parameter 4 : ffffcc05f265b980
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\112919-31890-01.dmp
Major Version : 15
Dump File Size : 892,948
Dump File Time : 11/29/2019 12:20:29 PM
System Service Exception - nvlddmkm.sys - Nvidia Display drivers
IRQ error - also blames Nvidia drivers.
Try running DDU and get new drivers - either get them from Nvidia or run Windows update and get them from there - https://forums.tomshardware.com/faq...n-install-of-your-video-card-drivers.2402269/
all errors could be the GPU drivers
ntoskrnl which is mentioned everywhere else is the windows kernel. It is what crashed but its never the cause. It does so much in the operation of the PC that if it crashes, windows has no choice. Often given bad instructions by drivers.
If you continue to get BSOD,
Can you go to C:\WINDOWS\Minidump
copy the minidump files to another folder
upload the files from new folder to...
upload the files from new folder to a file sharing website and show link here
